Micrologix 1500 to PC Communications
Thor Hammer
Jan 2014
Santa Cruz, CA
36
Been a while since posting here. I have a system that has been dumped in my lap and looking for insight. Here are the details.
PLC: Micrologix 1500
Server: Dell PowerEdge R220
OS: Windows 2012 R2
Comms: DH485 via COM1
Comms Driver: CimQuest IN-GEAR AB Standard Edition Configuration
I cant seem to get the COM1 port on the server as standard to communicate with the PLC. I can comm with the PLC with my laptop to download the program and such via DH485 protocol. No issues.
My question. If I setup my driver in RSLinx Classic as COM4 from my laptop will the PLC expect the PC to use COM4 as well for comms? I am new to all of this.
No, the PLC does not care or know what comm port your PC/Laptop is using.
Check to see if any thing else (software) is using comm 1 on your PC.
I figured it out. The Dell servers COM ports were the problem. Once I found which port was REALLY COM1 and set the I/O range correctly communications were achieved. (y)
Also, I had to set the default Comms switch to ON. Thank you for the replies!
Hello Engineers, Please help!! I am trying to connect Proface unit ST401 HMI panel to a Micrologix 1500 CPU over its channel 2 port. Can anyone...
3,649
89
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
921
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,210
