Micrologix 1500: Viewing error codes, does not work
asteroide
Jul 2010
der
158
Hi friends
I have a ARL Instruction (ASCII Read Line) that has activated the ER bit.
I would like to see the error code, according with the help I should add the ladder logic "Viewing_error_codes.jpg" I have done, but when I try to verify the project, 2 error appears: "RSLogix_Ladder.jpg".
I have changed some things, but the errors continues.
Do you have an idea?
Thanks a lot.
Hello
I am again with the same problem but with a Micrologix 1400.
Somebody could help?
Thanks a lot
Hello
Thanks a lot
Try the "CPW" ( Copy Word) instruction.
The "COP" instruction the source and destination must be the same data type.
The "CPW" instruction the source and destination data types can be different.
See PDF
so far, I haven't been able to get the "error reading" rung that you've been trying to use to properly verify with a MicroLogix processor ... (I even tried the CPW instruction that Mickey recommended) ...
but ...
I have been able to get the COP rung to work with an SLC-5/03 processor - and with an SLC-5/05 processor ...
so ...
as near as I've been able to tell (so far) - you're not going to be able to read the ASCII error codes ...
lesson to be learned: not all RSlogix500 systems work the same way "under the hood" ...
suggestion:
post your ENTIRE project file (RSS extension) and tell us which rungs are giving you a problem ... maybe we can come up with something to help ...
note that you'll have to ZIP the file before attaching it (forum rule) ...
good luck with it ...
HMMM? Going back to the PDF I posted the T,C and R data type(s) are not allow with the "CPW" instruction,nor the MG,PD data types. My bad in not seeing that.
Help to find IP address.
Hi everyone....
I need your help, I don't know what is the IP address from my Allen Bradley Micro820, has a fault and I need go online to check it and fix it do you know how can find the IP Address?
I will like to hear you soon...
95
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
923
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,434
