micrologix1000 and panelview300 micro help
otrex
Apr 2010
usa
iam new at this, so be nice,,,lol
can anyone tell me if the 300 micro can control a timer, and can it change the a fifu outpout bit
and if so how do i address it
Yes, but. You may want to give us a little more info on what you are trying to do.
fifu??
Click on help, then instruction help
Then you can choose
FFU
I think you are looking for FFL/FFU [First In First Out Load/Unload]
But I am not sure why you would want to have a timer control this, what is your application doing?
using ffl/ffu to keep track of bad bottlers going down a conveyor thats allway on..they are comming from a labler . I need only a few shifts, to get to the reject,,but need to change the unload position , when we change lable size and also the time off delay on the reject
oh , also have a move instuction that moves " 0" after it unload , just incase they stop the labler,,,,cause the reject would stay on. can send logix if it would help
I have never used a 300 before... but you should just be able to address the preset buy using T4:0.PRE , this would be timer 0
To add to the above, it's usually better to write to an integer then check it's value for a valid number then move it to the timer preset ( T4:0.PRE) as subjected above.
thats great , but still dont know how to program the 300 with panelbuilder to do this ,,,; dont understand : tags: i did get b3 . bit to toggle with a monentery f1 key,, then i was lost with timer change and position of ffu...maybe i shoulf just keep the ffu and change the ffl, cause of the move instrution..does anybody have a pva file that i can look at.... iam a quick learner, some thing simple cange timer , change ffl location...this is all i need
Same idea as the B3... and Mickey is correct (again :) )
In the panelview make a tag and an unsigned interger, N7:0 (example address)
Then use a MOV in the PLC and move the N7:0 to T4:0.PRE
ok,, for the timer to work for the reject and also put a counter to the # of bad parts....still need hepl in the shift....example ffl = N7:7/3 ffu = N7:2/3 . how can i tell panelview to change the the ffu to something like N7:4/3 or to change the ffl to N7:10/3.will need to change it not only one time but be able to change to any position that i want from the panel.
FFL/FFU pairs are used to move integers in a stack.
Your description appears to dealing with bits, so you may need to use a BSL or BSR instead (bit shift left, bit shift right).
Working on a machine that uses an Allen Bradley micrologic’s 1000 controller. Wondering if there is away to tie in the output to an external...
2,906
Hello, i made a program in rslogix500 for my micrologix1000 plc. can i import this program into the CCW software then convert the program which...
1,486
Could someone please guide me in the right direction? I currently own a 1761-L32BWB (Micrologix1000 processor) and a 1761-CBL-PM02 (programming...
4,493
Ihave a machine with a failed Moeller PLC that I have no documented logic for, and am replacing with a micrologix 1000 1761-L20BWB-5A. Most of my...
3,369
Hi all. Ive made a small I:0/0 push button and a O:0/0 light program to test that my plc is working. I got the bush button on a 24VDC and the...
35
5,263
