Micrologix1100 High Speed Inputs
DaveW
Apr 2005
SoCal
389
I have an 1763-L16BWA and I read that the 1st 4 inputs can be used as pulse catch latching or combined as a high speed counter. My question is what is a pulse catch latching and if I want to use the high speed counter for a pulse signal from a flow meter, does this mean I can't use the other 3 inputs?
Pulse catching came about as a function of how the Micro's and SLC's scan the I/O. If an input comes in for a very short period of time, the input scan may be too late to catch it. If you configure the point for pulse catching(latching) it will turn on the input on the next scan and keep it high for one scan.
It would appear that if you configure the HSC section of the 1100 that inputs 0-3 are taken up. It allows you to do quadrature, or count with up/down and reset. If you need more I/O, there are a bunch of expansion boards.
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1763-rm001_-en-p.pdf
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
478
Hi all. I have been give a job to remove an old plc and screen and change it to a newer AB unit like the machine sitting next to it. The problem I...
1,845
Hi, I am working on migrating legacy program from MicroLogix1000 to MicroLogix 1100 and apparently it's throwing an error saying the DDV...
1,647
Hi Everyone, I tried to do some searching and was unable to find what I'm looking for. sorry if this is not the appropriate place to post. I...
3,159
So the micrologix 1100 has a built in web server. I have been following the user manual 1763-UM002. After I enter in my controller's IP address...
1,203
