It normally defaults to C:\Program files(x86) Melsoft\GPPW.
Once you have uploaded the program & other files you can save as, then select say your documents folder & save it there.
Has this system got a servo drive or is it just a standard motor with an encoder ? also, a copy of the drawings if you have them.
The HMI is two generations behind & no longer made the same really goes for the PLC so it makes sense to upgrade this system
