Mitsubhisi Melsec
Deer
Jun 2002
124
Hi All,
I am familiar with AB PLCs but never use with Mitsubhisi PLC (Melsec A1S series)
What I want to know is about analog I/O card addressing.
Let say, I want to MOV value that comes from analog input module CHANNEL 0 that located at slot 3 (AIS63ADA) to analog output(A1S62DA)CHANNEL 0 at slot4
In AB PLC (SLC series) this can be done use MOV I3:0 to O4:0.Simple..
How about with MELSEC PLC, anybody can help?
Thanks in advanced
Deer
Hi All
What you must do is set up a "To" And "From" command.
I have this in my notes at home,I am on site today but when I
get home I can mail you on a copy of the code.
Donnchadh
First get the manual and read it.
You will find some stuff that is understandable only when you first understand it :(
What I mean is that the books are awfull.
Take a look at the section where it mentions BUFFERS.
Thats where everything happens.
You will have to write to some buffers to tell the card how to operate and then you will need to read some other buffers to get your data (or write to them in the case of outputs)
1 Buffer is set to ENABLE every channels.
1 Buffers is set to make averages of readings
1 Buffer per channel get you the data.
Other buffers deal with errors.
To write to buffer you must use the "TO" commands
To read you use the "FROM" commands.
Pierre,thanks for your reply...
I still difficult to understand to configure it, Mitsubishi PLC manuals is very poor to get it.
Ok, I already use "TO" and "From" instruction using GX Developer s/w,
when I make "TO" instruction at a rung,on the Detail, I should fill "Input Device" and I get explanation:
"Writes the data of "n3" points, which begin with the device specified at S, to the addresses starting at the address specified at "n2" of buffer memory inside the special function module specified at "n1".What the meaning is?
Thanks in advanced
Deer
Hi, I have PLC MITSUBISHI type FX0N-40MR-ES. At the moment, i have problem , the BOTH LED on front panel PLC are light on, it means CPU ERROR (...
1,880
I am having Mitsubhisi A series plc & 2 High speed Counter module. The counter modules Are placed 0 th Slot & 1st Slot of the Main base unit...
2,157
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
34
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
144
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
388
