mitsubichi serie alpha
Wess
Jan 2005
Mexicali
I'm learning the PLC serie alpha2 of mitsubichi, I wan to make a program that use the computer to send data to PLC and the PLC do something, for example... if i send a letter "A" the output 01 set on.
if anything have an example of this please help me.
thanks a lot.
I used Mitsubishi Alpha's years ago when i first started Programming and if what you refer to is the same ie And gates ,Or Gates,Simulation in the software and programming from Keys in front of the controller, Then i'd say it isnt possible.
Really these controllers are like Smart relays and cannot be classed as a PLC.
Maybe the series 2 is more advanced :confused:
Hopefully you will get a more positive result from the other Guy's.
Steve
Any good idea how to dim the display on a panelview plus performance serie b, at idel. Screen saver is not supported yet I have don it in global...
2,234
I have found a information in the user manuel of the CCW software, it's about the use of MODBUS TCP instruction : "A maximum of four message...
1,618
Hello friends i want to know how can i establish an communication between Cimplicity for example 8,2 and PLC GE Fanuc serie 6 please the pinout...
2,103
Hello i have a old PLC GE Fanuc serie 6 with card communication CCM2 this PLC is connected to a HMI Panel Nematron, i want to make a new hmi scada...
28
9,258
hi, i need the software of micrologix 1400 1766-l32BXB serie B, where can i download?
2,938
