Mitsubishi Error 2200
Oct 2004
51
Can anyone please explain the following error to me? I have created a very simple project and downloaded to a Q01. The processor remains in stop and will not run. I have determined that the following is what is stopping it. However, I do not understand what it is saying and what actions I should then take. Thanks.
Error code list[Error code 2200]
Applicable machine High performance model PLC, Process PLC
Error code(SD0) 2200
Error message MISSING PARA.
Common information(SD5-15) Drive name
Individual information(SD16-26) -
LED status(RUN) OFF
LED status(ERROR) Flashing
PLC operating state Stop
Diagnostics timing At power ON & reset
Error description & cause
No parameter file exists at the drive designated by the parameter enable drive switch(DIP switch).
Corrective action
Check/correct the parameter enabled drive switch setting.
Designate a parameter file for the drive designated by the parameter enabled drive switch.
Applicable machine Basic model PLC
LED status(RUN) OFF
There is no parameter file at the program memory.
Corrective action
Check and correct the setting of the parameter enable drive switch.
Put a parameter file in the drive designated by the parameter enabled drive switch
I just connected with Q170MSCPU and got the same problem, I see Q03CPU in GX Works2 but I can't see Motion CPU part of this controller.
How do you fix this?
No error 2200 now (I think it's related with non-existance of program in CPU at start).
Now getting error 7030.
Anyone can help? Any resources on programming motion controllers would be really appreciated!
I have a quick start guide for the Q170MCPU, but it is too big to attach here. If you want to pm me your email address I will send it to you.
-Dave
Hi All; Trying to make a backup of a Q02CPU. Used GXWorks2 to get the program and parameter files from the working CPU. The System is...
2,384
Hi I'm looking for some help on clearing the error code 2200 parameter missing.
3,598
Hi guys, Im trying to set the real time clock in my Mitsubishi FX1N, but it shows this error ES: 01800001 I have good communication with...
166
Hi, I have a project with a R04CPU, RD77GF16 and a RJ71PN92 modules. The cell is given to me to change the program since the previous integrator...
290
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
379
