Mitsubishi Ethernet Coms.
Carples
Dec 2007
sydney
Hello
Does anyone have any experence connecting a mitsubishi Q00 and an FX3U via ethernet.
What GX-D settings Do I use for each PLC
And which cammands are required.
I already have a touch screen, MX coponenets, and a bar coder running into the Q00 via ethernet
And can program Both PLCs via ethernet ports (both connected to same hub)
But can get to two to talk.
Hello, I am attempting to set up Ethernet coms between a L06CPU and a Cmore EA9-T6CL HMI via Ethernet with no success. There is no Ethernet...
1,892
I have a Mitshubishi FX2n with an FX2nc-enet-apd ethernet card which I am trying to connect 2 concurrent opc servers to Problem is that the...
2,419
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
860
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,816
Hello, I have a mitsubishi A800 drive with A8NEIP_2P that I'm trying to communicate with AB Ethernet/IP Card 1756 ENBT/A. I have everything setup...
1,317
