Mitsubishi F2 to FX2N Conversion
price43
May 2007
Illinois
I am upgrading some Mitsubishi F2-40MR PLCs to FX2n's. I can extract the old programs with a DOS version of Medoc. I have GX developer FX version. How can I convert the old F2 programs to a format GX developer can read & edit?
Any help would be appreciated
I suggest to upload program from PLC using GX and convert PLC model after . But you will lost all coments.
Hope it help.
Sergei Troizky said:
There is Import Medoc Format File option in the Files menu.--It does not work with 32 bit Medoc(2.41).
However, I doubt that GX-Developer-FX supports F2 PLC.
-- Will check Monday.
When you will have read the program with MEDOC, Back it up then change the PLC model. It will give you a ladder where some rungs comes or got to "emptyness". These you will have to modify for there come or go to and from unexisting addresses.
Its pretty simple.
You can use Gx or Medoc to work but will have to upload from Medoc.
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
963
I have been asked to work on a Mitsubishi Melsec FX2N-80MR PLC but have no experience with Mitsubishi at all. The hope is to get online to find...
1,350
Hi all IÂ’ve never worked with Mitsubishi PLCÂ’s or software, but a customer at our branch has requested the PLC program for future...
786
1,644
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,109
