johnfarrugi
I am working on a job trying to add a FX2N-232IF to a fx3u PLC. I have never worked on a mitsubishi PLC before, although I have years of PLC experience.
From what I see, I can just attach the rs232 module to the rack without changing anything in the program. is this correct?
The application consists of four keyence BL1300 barcode scanners connected to a keyence N-410 Master. When any of the barcodes read, the data is sent back to the FX2N-232IF module in the format:
STX %01 123456789 ETX
The %01 represents the scanner address number which sent the information.
From my understanding, I need to setup a few TO functions to setup the communication in the FX2N-232IF module. Then I need to request a read or FROM command in order to read the buffer in the module.
Does anyone have any examples of this type of code?
I am trying to figure out what happens if I get two scanners that send the information at the same time. How do I only read one command from the buffer?
