Any ideas why this would be happening? This is the code I read from a EEPROM in a Mitsubishi FX2N. It was previously working and for some reason the PROG-E light started flashing, when I connected I discovered it was giving a check sum error. I then realised that a END instruction had been inserted at step 2000 (is it step 2000? I dont really know much about these).
After deleting the END instruction,the RET instruction and the abnormal instruction codes the ladder view came up fine again and I was able to write it back to the PLC.
Only problem is I dont have a copy of the original code so I'm not sure if the program is 100% correct after my edits. It could be that the insertion of the END instruction actually overwrote something.
Help appreciated. Thanks.
