Mitsubishi fx2n plc
ovascotom
Aug 2006
kentucky
I am looking for help, I am new with programing.
I am using a high speed counter on a a print press for registered printing, and speeding up and slowing down the mat. on a continuious run in order to pu the print where I need it to be.
but the counter is going over and under the preset count causeing
the print to land in differant place's. I believe it is because of the scan time.
Is this a new application? Or has this been working?
Have you made any changes to it?
I don’t know Mitsubishi’s very good, just learning, but I would doubt if it’s the scan time that is causing your issues
Can you post the program you may get a better response (PDF) if you can
is this a sheet feed or web ?
Have you checked the mechanical side of the encoder? Is it slipping?
Yes this is cont. web
the drum is a fixed speed mat speeds up to reach set dist.
then slows to match drum speed for print.
M8000-------------------------------C235 K9999 DRUM
M8000------------------DHSCS K3717 C235 M1000
NC/M8000-------DHSCR K3717 C235 C235
M1000------------------------------C236 K9999
RISING PULS
M1000-----------------DHSCS D136 C236 M2000
NC/M8000--------DHSCR D136 C236 C236
RISING PULSE
M2000-----------------------------RST C236
M2000-----------------------------RST M1000
Oh! Yes This Is New Aplacation
It Is An Old Print Press But Done A Refitt Took Out All The Macanical Timmers And Put In The Plc To Do A Registered Print
Whent From One Drive To 6 Drives Useing 2 Mitsu A700 Vfd's
And 2 A 500 Vfd's With A Didital Card To Talk To All Of Them
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,083
Hi everyone, I am new here and this is my first post. I've just received my new PLC by post. It is a FX2N-20MT, a chinese clone of a Mitsubishi...
28
18,401
good morning every one I have a problem in Mitsubishi plc fx2n the battery led is on and progE/cpuE led flashing the plc in a machine which runs...
2,047
For some background information, I am in the process of converting a Mitsubishi FX2N to a Siemens S7-1200. I am viewing the Mitsubishi program...
2,835
Hi Dear friends, My Mitsubishi PLC FX2N-80-MR has stopped working and Prog-E led is on.What Can be The reason.Please guide. Urgent. thanks In...
6,623
