Mitsubishi GX Developer question
STL???
Sep 2005
UK
879
I need to add an additional open contact -| |- to a rung which has no spare space, I have noticed in other parts of the program that the rung can be extended onto the next line and given a reference like the JPG below:
Can someone put me out of my misery by explaining how this is achieved
Thanks Steve
I have just tried it, you just keep putting contacts on until the line is full and it automatically wraps to the next line, you dont have to 'DO' anything
Extending Rung
If the rung is full press CTRL+INS where you want to add a contact and it will extend onto the next line.
Also from the menu, if you go to VIEW---SET THE CONTACT then you can display the rung either 9 contacts wide or 11 contacts wide.
CTRL INSERT!!!!!!!
thats the one! cheers Michael,tried "set the contact" before i posted but the Editor was already set to 11 contacts.
Thanks Steve
Hello, This picture is showing a function in Mitsubishi Gx Developer (V7.04) the function is moving the first 16 bits from the array...
2,635
Found a Mitsubishi Fx-30MR-ES plc and a new programming lead and the Gx developer software in a box, I think none of it ever used. My question is...
3,555
Is there a way to export and import the tag list from a project? What I have to do is take an existing project and re-address it. It looks like...
2,802
This is a problem I’ve encountered numerous times but have never been able to cure, so I just thought I’d see if any of the Mitsubishi experts...
2,977
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,183
