Mitsubishi Ladder
userxyz
May 2002
any
2,768
Anyone who understands and can help with this Ladder networks in Mitsubishi:
Thanks,
Regards,
Combo
Q Series?
it has been a few years since i did any Mitsi programming and my memory isn't what it was (my hairline either)
SM403 from memory is an 'always on' bit
[MOV K3X0 Z0]
MOV = Move
K3X0 = Read 12 bits starting at Input address X0
K1 = 4 bits,K2 = 8 bits,K3 = 12 bits,K4 = 16 bits when used with this type of instruction.
Z0 = Index Register 0
i've used Z registers in the past for indirect addressing.
[>= K9 D126] etc = if the D register is greater than/equal to 9
MOVP = Move with rising edge pulse
The other instructions i haven't used however if you go into the instruction detail (double click it) you should see a brief explanation of what each instruction does.
I don't have GX developer installed currently but hopefully what i've wrote should get you started.
Thanks !!
Could you also help with my other post ?
http://www.plctalk.net/qanda/showthread.php?p=561425#post561425
Thanks,
Regards,
Gerry
Q Series?
[MOV K3X0 Z0]
MOV = Move
DIS instruction take Z0 (16 bit word) and separated in 4 bit units and store it in "D126" "D127" "D128" "D129"
See the attached picture
Dear All, I have an Mitsubishi PLC (FX1N-40MR) and PLC backup was taken and i compiled the program and its showing 0 error. then I tried to...
290
Hi guys, Was wondering if someone could help me with some ladder logic on a Mitsubishi FX-64MR which we are using for running air compressors...
2,042
I have downloaded a project from a Mitsubishi Alpha PLC that we are having issues with and the representation is Boolean. Is it possible to...
1,675
Hi everyone, I am a greenhorn in programming. Can anyone help me with a GX Works ladder logic example of programming a real time clock. I want to...
4,030
Hai All, Am using GOC35 mitsubishi PLC in that plc i need a pid instruction in ladder format.so i used and i give a process value,set value...
1,743
