Mitsubishi Melsec A1SJH cpu
plc_beginner
Aug 2016
York
Hi all,
Im a beginner a programming PLC's, so if anyone help with some of my questions, that would be highly appreciated.
Currently I'm working with a Mitsubishi Melsec A1SJH cpu PLC and am trying to establish communication via an RS232 to ethernet converter. However, I'm not sure about how to setup the communication with the PLC. Seeing as there isn't any ethernet module on the PLC, I'm guessing that there needs to be a ethernet to Melsec communication protocol conversion before establishing communication, and if I'm not mistaken, the communication protocol used by Mitsubishi is the Melsec Communication Protocol.
I do have a SC-09 cable connected to the PLC which is connected the PLC, then a RS232 from the other end of the SC-09 cable into the serial to ethernet converter box. The ethernet cable is only connected from the converter box to my PC. I'm wondering whether the Mitsubishi Melsec A1SJHCPU PLC requires more pins of the RS232(Apart from TS,RX,GND).
I normally use a serial-to-usb converter with my sc-09 cable, never had any issues. I suggest you buy one, it is cheap anyway.
I've tried that and it yes it does work. However, what I'm trying to do is use that converter box as a serial server and use it to monitor data from the PLC via Kepware.
The SC-09 cable is mainly use to upload/ download PLC program only. If you need to monitor PLC data via kepware you need to buy an ethernet module for your PLC, and do some programming. The programming instruction is usually on the programming manual.
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
521
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
952
I have been asked to work on a Mitsubishi Melsec FX2N-80MR PLC but have no experience with Mitsubishi at all. The hope is to get online to find...
1,341
I have an 80's PLC, Mitsubishi K2NCPU that needs replacing. Is there a software / cable available to upload and print the current PLC program? Thanks
949
We received a cell that has a MELSEC Mitsubishi FX 2N-80MR PLC installed. We need to access the PLC program for troubleshooting and additional...
1,982
