Mitsubishi PLC FX series
Dec 2013
Chittagong
19
Dear,
Hello! Hoping everyone is fine. Friends , I need some retentive data register , retentive counter , retentive timer of mitsubishi PLC fx0S serise which can retain its memory during power failure. I know about retentive timer but it does not work with my fx0S series. My advance appreciation for any help.
I have attached my file .......... i have used counter and register but they are not retentive. I want retentive type.
Allah Hafiz .
Saifuddin
Firstly, you didn't zip the program up correctly. half of it is missing and so it's - unreadable.
The FX0s is a basic plc and so does not have many retentive registers or counters. It has only 2 of each (that might be enough though - I don't know)
C14 & C15 are retentive counters and D30 & D31 are retentive data registers and I don't think there are any retentive timers with that model.
If you're not using both of the two retentive data registers you could just use one of them as a counter (using inc or dec and comparing the value to a target etc)
87
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,201
Hello everybody! I found option for creating communication with Q series via python. But can't find any tips for connecting with PLC FX series...
5,656
using Q03UDV plc &QY42P for outputs.....working ok i want to use new output ..download the programm but output does not show 24 v in...
16
3,290
Hi, I need to send a digital output to turn a water pump Inverter driver ON/OFF. To this end, I'm planning to use a Digital Output Module, i.e. it...
16
3,570
