mitsubishi servo controller
REZAR
Aug 2003
Jakarta
95
guys, i need to give quotation to customer. tomorrow!
what type would u choose for controlling z axis of machining m/c ?
for mitsubishi plc A series
the best money can buy ;)
What are you trying to do? What power? Why use A PLC?
Is it existing machine? What do they have now?
There are couple of positioning modules for A series PLC
but IMHO, A is ok for upgrades only, it is too old for
new installations. You can find cheaper and much more
powerfull PLCs in smaller form factor.
If you go to Mitsubishi website You will find couple of manuals
for products that could be used for this. If I had to do it,
I'd probably look into A1SD75M1/M2/M3.
Have fun with motion...
Some manuals:
IB(NA)66561-A 152.87KB PDF
AD71S2 POSITIONING MODULE USER'S MANUAL (HARDWARE) 152.87KB PDF 8/18/2001
Technical Manual IB(NA)66562-A 140.14KB PDF
AD71S7 POSITIONING MODULE USER'S MANUAL (HARDWARE) 140.14KB PDF 8/18/2001
Technical Manual IB(NA)66563-A 10.86MB PDF
AD71S1 S2 S7 A1SD71S2 S7 POSITIONING MODULE USER'S MANUAL
IB(NA)66715-D 7.31MB PDF
A1SD75M1/M2/M3 AD75M1/M2/M3 Positioning Module User's Manual
IB(NA)66733-C 193.12KB PDF
AD75P1S3 P2S3 P3S3 POSITIONING MODULE USER'S MANUAL (HARDWARE) 193.12KB PDF 8/18/2001
Technical Manual IB(NA)66734-E 176.19KB PDF
A1SD75M1/M2/M3 Positioning Module User's (Hardware) 176.19KB PDF 8/18/2001
Technical Manual IB(NA)66735-E 183.14KB PDF
AD75M1_M2_M3 Positioning Module User's (Hardware)
IB(NA)66823-B 1.38MB PDF
High-Speed Counter Module type AJ65BT-D62_AJ65BT-D62D_AJ65BT-D62D-S1 1.38MB PDF 1/28/2003
Technical Manual IB(NA)66824-A 4.79MB PDF
AJ65BTD75P2S3 POSITIONING MODULE USER'S MANUAL
Once again I have stumbled upon a new dilema. I am trying to monitor the near dog signal going into my QD75MH2 Servo controller, but when the...
1,540
Hi everyone. I try to using FB MC_MoveAbsolute, but Fb was error [1103 A value out of the range is set as a commanded position or travel...
849
we have a pipe cutting machine that was out of use for a long time, so the battery for plc was gone. I replaced plc battery, but now both servo...
1,019
Hi I selected a Mitsubishi Servo drive MR-J4-100TM-PNT for profinet communication. The supplier I am getting from this particular drive doesn't...
1,416
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,258
