ML-1400 to CompactLogix L33ER messaging
Yacineg
Oct 2020
Guj
54
I am trying to read a block of data from an ML-1400. The data is in the form of floating-point numbers. I am only able to read only 59 numbers using 1 message instruction. I have to read about 195 numbers. What can I do to read all the numbers using 1 message instruction? We are currently using 3 message instructions to read the same data.
Is your MSG instruction being executed in the MicroLogix or the CompactLogix ?
What is the exact address or format of your data ?
236 bytes of payload sounds like it's under the usual limit for PCCC or EtherNet/IP frames, but I don't have those limits at my fingertips, except for the classic 510 byte CIP frame payload limit.
The obvious answer is "keep using three MSG instructions" but I'm curious about how this limit expresses itself. Does the MSG fail with an error code, or do you get an error message in RSLogix when you try to enter the addresses and sizes ?
Thank you.
The MSG instruction is being executed in the CompactLogix.
The address for the MSG instruction is the float file in the MicroLogix.
The MSG fails with an error code. The error code also has some text, both of which I am not able to recollect right now.
Hi all I'm trying to setup a MSG connection (which I'm not familiar to) between a CompactLogix CPU (L310ER) and a Micrologix 1400 CPU. At the...
811
Hi everyone, Brief overview of the issue: I have a CompactLogix (pt No:1769-L36ERM) that is connected to a MicroLogix 1400 (Pt no: 1766-L32BXB)...
4,301
Hello Everyone, I am trying to pull a few data table points from a MicroLogix 1400 L32AWA Controller into a CompactLogix L30ER over ethernet. I...
1,599
Hi! We sell control cabinet equiped with Micrologix1400 CPU and PanelView Plus 6 700 HMI and a powerflex 4m communicating with modbus to the PLC...
2,735
Hey everyone, I've recently returned to the automation world after several years absence. I have been tasked with changing the network scheme of...
2,055
