ML1100 measue negative voltage on analog input
arnk
Jun 2008
Swindon
26
Please can anybody recommend a way of measuring a negative voltage (-40 to -60V dc) on the analogue input of an Allen Bradley Micrologix 1100 PLC.
The manual says that the common terminal is connected to ground so I cant just use a voltage divider and reverse the analogue input connections. I guess I will have to use an opto isolator of some sort. The negative voltage is from a battery.
Al
I'm looking to implement a low-cost, efficient method of communicating some integer values to an R30iB robot from a Rockwell 1100 PLC. I am not...
1,727
Hello all, I am trying to setup my MicroLogix 1100 as a modbus RTU master for a modbus network containing multiple modbus RTU slaves. I currently...
3,928
We have a machine that keeps losing its program at random intervals; sometimes 2x-3x in a shift, sometimes will go over 1wk without issue. I had a...
2,944
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,586
I have a CLX L61 and I'm trying to read from and write to a Micrologix 1100. I'm attempting to read 200 REAL elements but I'm receiving an error...
1,459
