ML1100 set point, where to place
MaxGauss
Mar 2013
Spring Hill, Florida
Dear Sirs: I am working with PID on the MicroLogix 1100. Where do I place my "Set Point"? There seems to be no accommodation in the PID block for it. I took my Set Point integer and moved it to PD9:0.SP, word two (2),but the system will not accept it. Sir's, Please, where do I place the silly thing....
ps.. Ron thank you so much for your help yesterday.
try PD9:0.SPS ...
something in your question makes me think that you MIGHT be confusing the ways that the PID function is used in various models of RSLogix500 type systems ...
in RSLogix500 there are TWO types of PID instructions ...
(1) one uses an Integer type file (example: N9:0) for its Control Block ...
(2) the other uses a special PD-type file (example: PD9:0) for its Control Block ...
yes, I know that the help files tend to run around in circles ... just be careful that you're reading about the RIGHT type of PID for your particular system ...
you need the PD-type for your MicroLogix 1100 ...
incidentally, the location that you mentioned - PD9:0.SP is a binary BIT address ... it can only hold either a ONE or a ZERO value – not an analog value like a setpoint ... that's the reason why the system wouldn't accept/allow your entry ...
basically the processor turns that bit to a status of ONE whenever the setpoint for your PID happens to be "out of range" ... in some cases you can program your logic to let the operator know that he's fat-fingered the keyboard - and to keep the PID (bless its little heart) from choking on an out-of-range setpoint entry ...
just a suggestion:
when you get finished with your project (or even just a little further along with it) consider posting a copy of your entire RSS program file here in the forum ... (you'll have to zip it first - forum rule) ... we'll be glad to take a look at it for you ...
many (most?) people consider PID to be the "deep end of the pool" ... having some extra eyeballs on the program probably wouldn't hurt anything ...
what's your deadline on getting this thing working? ...
I'm looking to implement a low-cost, efficient method of communicating some integer values to an R30iB robot from a Rockwell 1100 PLC. I am not...
1,734
Hello all, I am trying to setup my MicroLogix 1100 as a modbus RTU master for a modbus network containing multiple modbus RTU slaves. I currently...
3,947
We have a machine that keeps losing its program at random intervals; sometimes 2x-3x in a shift, sometimes will go over 1wk without issue. I had a...
2,951
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,598
I have a CLX L61 and I'm trying to read from and write to a Micrologix 1100. I'm attempting to read 200 REAL elements but I'm receiving an error...
1,468
