ML1400 - Does ETH MSG require 2 registers?
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
In the PLC 5's when you created an Ethernet MSG instruction you were required to skip every other MG register because that's second register where the multihop data was put.
Is the same true on an ML1400?
In a Micrologix1400, you have to create a Message (MG) data table and a Routing Information (RI) for ethernet messages. It uses one element for each data table per message.
Doh! OK that makes sense. RI contains the multihop info so the second reg isn't needed.
I thought it was purely a workaround only on the PLC5s.
Hi all, I have my own driver to communicate with a MicroLogix 1400. Please refer to the attached screenshot from Wireshark. 10.10.21.10 is my...
2,007
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
508
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,449
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,230
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,837
