ML1400 Ethernet and 485 Comms
harleymc100
Jan 2014
london
21
Hi guys, newbie question here.
I have my ML1400 Communicating on an Ethernet network (Ch 1 ).
I also have a pH controller that can communicate via RS485. I wanted to read the pH data via 485.
My question is, can i communicate with this device through Ch 2 of the ML ??, as well as using ethernet for my network? ie, at the same time?
I was going to cut up a 1761-CBL-PM02 cable and connect the Txd/Rxd cores.
Thanks!!
I don't think all the wires you need are present in the 1761-CBL-PM02 if you intend to use RS-485. Buy a 1761-NC01 and make life easy.
Also when you set up the channel, pick the option RS-485 No handshaking in order to activate the RS-485 signals on that port.
One more thing, CH2 is the 9 pin D shaped connector which is RS-232, I think you will have to use CH0 for RS-485
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
840
Hello, I am trying to use micrologix 1400 Ver.A as adapter and a Productivity P1-540 as scanner, only Ethernet/IP is supported by ML1400 Ver.A...
1,855
I am having trouble where upon power up the ML1400 fails to communicate to any other network devices. If the ethernet cable is removed and...
3,733
Hello, I have an application with 12 FTView ME computers connected to a MicroLogix 1400 using Ethernet. My application works fine but the reaction...
3,073
I am using a MicroLogix 1400 connected by Ethernet to a "private" network at work. I made an application using Studio 5000 ME on desktop...
1,517
