ML1400 ethernet Bandwidth
clupie
Jun 2017
Illinois
I am using a MicroLogix 1400 connected by Ethernet to a "private" network at work. I made an application using Studio 5000 ME on desktop computers. There are a total of 12 computers using a .mer file. Each computer is talking to a single Compact logix that is connected to the switch at the cell and also talking to a ML1400 in the back of the building using the "private" network. So the ML1400 has 12 computers connected to it using the "private" network. The problem I'm having is the reaction time of my application. The reaction time for the compact logix is great but when I connect 12 cells to the ML1400 the screens for that system are very slow to react. 4 to 5 seconds to change states. All I'm doing is enabling cell users and updating a status board on who is using the system. No big calculations.
I've tried changing the max tag update rate on the screens with no success. Tried deleting several displays from my .mer application. No luck. If I have only 2 or 3 cells talking to the ML1400 the reaction time is great so it seems to be a bandwidth issue. I have not talked with my IT network guy yet, just thought I would put something out there for ideas.
Thanks for the help
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
843
Hello, I am trying to use micrologix 1400 Ver.A as adapter and a Productivity P1-540 as scanner, only Ethernet/IP is supported by ML1400 Ver.A...
1,855
Hi guys, newbie question here. I have my ML1400 Communicating on an Ethernet network (Ch 1 ). I also have a pH controller that can communicate...
1,757
I am having trouble where upon power up the ML1400 fails to communicate to any other network devices. If the ethernet cable is removed and...
3,736
Hello, I have an application with 12 FTView ME computers connected to a MicroLogix 1400 using Ethernet. My application works fine but the reaction...
3,083
