Ml1400 hsc
roxusa
Nov 2008
NJ
994
Setting up the Function file for the HSC as Mode 8 I think I only use the
A+ & B+ inputs on I:0/0/0 & I:0/0/1. Why do they show A/C & B/D for
the inputs on those (HSC:0) I am reading 1766-rm001 -en-p literature.
My encoder has A+,A-,B+,B- Do I only need the A+ & B+
I have used the ML1400 HSC before but never with an encoder that had +&-
My encoder is 2500 ppr if I use mode 8 with just A+ & B+ should I get 10000
ppr. I haven't done this enough to be familiar with it. Thanks
How to wire a Differential encoder to ML1400. Using the HSC I have set up the HSC before using Single ended but have a nice US Digital...
1,119
I have programmed a cut-to-length system on ML1400 which I am simulating with a voltage controlled oscillator driving HSC:0. The program uses a...
1,542
Hi Guys I'm new to Allen Bradley and I'm trying to figure out how to get a simple encoder input into the MicroLogix 1400. After looking through...
5,828
Hi Guru's I have been trying to set up my HSC interrupt (HSC:0/HPI)to trigger a counter in my ladder logic. I read the manual like 5 times and I...
4,356
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
495
