ML1500 analog out problems
mto ind
Apr 2005
I'm new to analog programming and have a problem with my 1769-OF8V output card. This should be straight forward since I am only opening a valve with my 0-10vdc signal using a SCP instruction. The problem I have is I have a constant 5vdc signal at all 6 of the outputs I have enabled on the card but the ladder still shows 0.
INPUT N7:30
MIN 0
MAX 32767
SCL MIN 0
SCL MAX 10
OUTPUT O:5.0
No matter what value is in N7:30 the output remains at 0 and I still have 5vdc at the card.
Settings for each channel are Raw/por, 0-10 and no clamping. It acts like there is a setting wrong, but I don't see anything else.
Side note. PLC=Micrologix1500. Ive tried different scaling and min max values just to see if it makes a difference but it does not.
You have the parameters reversed. For an output, the result data is 0-32767 and the input data will be 0-10 VDC.
Here is an example from a ML-1200, with my control parameters scaled 0-6000 where 6000 => 60.00 Hz. Also, this was a 4-20 mA output, so I have the 20% offset in the output. This should get you started, though.
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,361
Hi all, PLC : Micrologix 1500 lrp HMI : Renu FP3070 TN I am a beginner in the plc world. I am trying to connect the renu hmi with ML1500 lrp in...
768
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,230
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,206
Hello, I have the PLX setup and configured. Its seen and downloaded to. However my ML1500 does not communicate over it. The port (0) is used...
1,657
