ML1500 CPU burns out frequently
lalprasob
May 2012
kerala
Hi friends........i am facing the following problem with ML1500 LSP CPU....ML1500 CPU in my system burned out 2 weeks before...i changed the CPU...Within 18 Hours , the same problem repeated..Then i checked all wiring and earthing and installed new one....it worked for 13 days...After that the same burning problem repeated.......i cant find out the reason....pls help me..
System configuration is- ML1500 LSP Series C, 28BXB base , 3 IQ32 and 3 OB32 ( total of 6 modules connected with CPU )...no PA2 used...
Are you powering the outputs with the same power supply as the CPU?
If so do you have surge protection on all inductive loads?
Welcome to the forum,
I understand "God's own country" is infamous for frequent power outrages and voltage fluctuations.
You may need some considerations to have a steady supply to the PLC.
Regards
Hi Mickey,
I am using 3 SMPS's. one for PLC CPU, one for all digital inputs , one for all digital outputs...I have not used any surge protection circuits.......I have provided UPS for SMPS of PLC CPU only.....is this configuration will create any problem?..pls reply
Hi Mickey,
Here is a guide for you. See PDF
if temperature will be a factor for this type of PLC failure? When i observed the temperature of PLC CPU during operation, i got the value above 45 degree celcius......The PLC system is installed in the harsh environment of a steel plant where temperature is always high...Air conditioner installed in the PLC room was not in a working condition during this PLC failure.....
See spec
Hi all, PLC : Micrologix 1500 lrp HMI : Renu FP3070 TN I am a beginner in the plc world. I am trying to connect the renu hmi with ML1500 lrp in...
770
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,365
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,234
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,216
Hello, I have the PLX setup and configured. Its seen and downloaded to. However my ML1500 does not communicate over it. The port (0) is used...
1,661
