ML1500 CS1 Function File Troubleshooting
Chrometool
Jun 2004
Michigan
G'day to all..
I'm having a problem using Ch.1 ASCII on a ML1500-LRP. I need to use 9600, 7, E, 1 data and have Ch.1 setup as 9600, even, no handshaking, with default /d & /ff termination characters.
No problem transmitting from Ch.1 to a PC running SimpTerm. The problem is that Ch.1 will not properly receive data from the PC!
1) I send one character to Ch.1 and do not see any buffer length changes in the ACB instruction
2) I do see the Function File CS1:19 (bad character count) increment each time, I send a character to Ch.1
3) When I change the data frame in the PC and Ch.1 to 9600, 8, N, 1 (9600, none) the PLC transmits and receives fine....
Soooo.... can I assume that CS1:19 for ASCII will increment every time and invalid data frame is received?
Where's the Bug?
4) RSlogix 6.0?
5) ML1500-LRP, Ser C, Rev D, FRN 9?
6) ME?
Thanx in advance for any and all replies :p
Hi all, PLC : Micrologix 1500 lrp HMI : Renu FP3070 TN I am a beginner in the plc world. I am trying to connect the renu hmi with ML1500 lrp in...
771
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,365
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,234
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,216
Hello, I have the PLX setup and configured. Its seen and downloaded to. However my ML1500 does not communicate over it. The port (0) is used...
1,662
