ModBus and Profibus
Waseem1234
Apr 2018
Lahore
Hi Everyone!
I am feeling some troubles while dealing with Profibus and Modbus.
Is there anyone who can help me out in following questions?
1. What are the major differences in Modbus and Profibus?
2. In what scenario one should use Modbus or Profibus?
3. What will be the configuration/ connections layout at hardware level for both Modbus and Profibus? (Special Thanks for this answer )
4. can the profibus use "msg" instruction to get values from the module?
5. for what purpose "Profibus Configuration Builder" is used?
Thanks in advance!
1. The color of the cable
2. When you have a Purchase Order
3. Connector with holes attach to socket with pins
4. “Yes”
5. To build the profibus configuration
For extra credit:
The protocol
Pick the one you know
Plugs and Cables
4. “Yes”
If he asks nice
You downloaded the software, might as well us it..
hello I use S7-317 CPU in new project to control production line. I use two old DC motor drives...in old configuration they were controlled...
1,755
Iam working on link PLC S7-317 2PN/DP as master using profibus to two old slave speed drives which have only modbus (rs-485) after search I...
2,020
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,284
Hi all I want your advice for my problem : I have two PLC control systems , first is an old one and I use an Intouch Scada system to monitor and...
3,400
I have a Pfister Universal CSC Controller that has a CAN-Bus/Modbus-RTU port for networking but I have a profibus networking. Now I want to make...
1,622
