Modbus / Profibus network question
sikeoboy
Jul 2008
Vancouver
Hello all,
I am theorizing to have a network with a Modicon PLC acting as Modbus Master, with a number of slave devices (PLCs with Modbus slave modules - some PLCs GE Fanuc, some Modicon Quantum) attached to the network.
Now, is it possible to actually have a slave on the network commmunicate directly to another slave, or perhaps by using the master as a gateway so to speak?
Assuming I change the above qn to be using Profibus instead of Modbus, does this make a difference? Or do the networks operate in a similar fashion?
Thanks in advance!
Rob
With Profibus it is not possible for two slaves to talk to each other. You can however use a master to read the data from slave 1 and send it to slave 2.
I have no idea if it is possible with Modbus. But if it also has a master-slave structure then it will be the same as Profibus.
Hi Everyone! I am feeling some troubles while dealing with Profibus and Modbus. Is there anyone who can help me out in following questions? 1...
2,513
hello I use S7-317 CPU in new project to control production line. I use two old DC motor drives...in old configuration they were controlled...
1,764
Iam working on link PLC S7-317 2PN/DP as master using profibus to two old slave speed drives which have only modbus (rs-485) after search I...
2,026
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,292
Hi all I want your advice for my problem : I have two PLC control systems , first is an old one and I use an Intouch Scada system to monitor and...
3,403
