Modbus Simulation/Read Software Recommendation
John Marston
Apr 2015
Chuparosa
54
Hello All, I used to use DDE drivers to read my Modbus cards but Microsoft has deemed that to be unfit for the newer versions of Office. I need to get some new simulation software that can read Modbus over RTU/TCP-IP. I've looked at Simply Modbus and like its layout but it doesn't appear to let me look at each address at the bit level (coils). Do you guys have any Modbus software that you like using and would recommend?
Hello,
Would you please clarify? Are you asserting that some or all of MS Office 2016 (Excel, Word, etc.) does not DDE support?
Hello,
No, I was meaning it isn't as easy as it used to be to poll data via DDE. I had some server softwares that worked great with excel 2003 but now it doesn't work at all. So, naturally I blamed Microsoft.
OK, thanks.
I was about to install 2016 and no DDE would put a kink in the plans.
I have a program for a PLC, but I don't have the PLC now. I am running the PLC program in the Codesys simulation mode. Can I connect SCADA to...
1,733
What is the best Modbus simulation software to purchase? I have found several on the internet and I need to be able to work with all flavors of...
1,555
Dear All, In real Time Iam Communicating Modicon PLC (Modbus data ) to INTouch HMI through DASMBTCP protocol. The communication is established...
4,531
Hello guys, I have some question about modbus simulation between PLC and laptop. However, The PLC and the slave simulator actually not...
5,399
Into something I have never had to do. For a new project I must perform some testing of Modbus master setups without having the actual slave...
6,740
