Modbus Simulation
srinathair
May 2016
Dear All,
In real Time Iam Communicating Modicon PLC (Modbus data ) to INTouch HMI through DASMBTCP protocol. The communication is established and working fine.
Now i need to simulate through RSim or Modscan simulate software instead of Modicon Hardware.
I tried using within same PC with configuring as Local Host (Intouch, SMC & Rsim in Same PC) and also tried with Rsim separate PC and Intouch in other PC whereas i could not establish the communication.
My intouch PC IP is 192.168.1.100 and Modscan as 192.168.1.200
Can you help with the configurations or is there any way to simulate modbus??
Good Question!!.
Plant is in Operating Condition and i cannot play with the real system for trial and error.
I got some variations to implement whereas i cannot test with the actual.
I have a program for a PLC, but I don't have the PLC now. I am running the PLC program in the Codesys simulation mode. Can I connect SCADA to...
1,736
What is the best Modbus simulation software to purchase? I have found several on the internet and I need to be able to work with all flavors of...
1,559
Hello All, I used to use DDE drivers to read my Modbus cards but Microsoft has deemed that to be unfit for the newer versions of Office. I need...
1,788
Hello guys, I have some question about modbus simulation between PLC and laptop. However, The PLC and the slave simulator actually not...
5,402
Into something I have never had to do. For a new project I must perform some testing of Modbus master setups without having the actual slave...
6,741
