Modicon Concept 2.6 TOTALIZER block
dmned64
Jun 2013
Florida
99
I hope to use the Modicon Concept TOTALIZER block to totalize a flow rate. I have set up a test in the simulator to familiarize myself with the block and I believe I understand how most of the parameters function. On thing eludes me, the time rate on which the block is based.
When I set the flow_rate to '1' the ones values *seem* to increment at one second intervals. Similarly when I set flow_rate to '10' the tens values increment every second. This would seem to work if the flow_rate was units/sec but not if the flow_rate value is units/min (or anything other than units/sec).
If flow_rate is units/min I could divide it by 60 to get units/sec but it seems one of the settings of the TOTALIZER block should be able to define this time period.
Attached is a screenshot of how the block is setup in the simulator.
Thanks,
Dean
My hard drive crashed on my PC that I was running an old version of Concept. I still have the installation disk but do not have the activation...
1,346
Good day, Is there a way to stop displaying the execution order in the IEC ladder sections of the program. The order started displaying when...
2,060
Hi Gents, I am not familiar with Concept (familiar with Modbus however) and I was asked a question from one of my customers about an error they...
2,888
Pretty new at Concept (AB guy). I have an XXMIT that handles communications with a dozen remote RTUs. I want to monitor the Error and Done bits...
1,722
Hi, I am new to Concept, and I am trying to connect up to a Modicon Quantum processor using Mod Bus+ Everything appears to be good, it sees the...
2,232
