Modified parameters on PowerFlex VFD
Seb94
Aug 2021
fr
25
I'm currently working on a machine equipped with Rockwell PowerFlex VFDs. I have one PowerFlex 753 (rev 6 or so) and two small PowerFlex 4M.
I configured them using DriveExecutive, all went well.
However I wonder if there's a way to visualise modified parameters or export a file that only contains these parameters. DriveExecutive can generate an XPS file with all params, but ideally I'd like to avoid sorting through all these lines.
Schneider ATVs have this functionality and it's quite practical when verifying the VFD config.
Thanks in advance, regards
Thank you.
I shall open my .dno file in CCW then, and print the modified parameters.
To anyone looking at this thread: I do not recommend using CCW (at least, on ~10 years old equipment)for configuring VFDs because it causes a lot of bugs.
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
134
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
Hi, I'm working on a project (AB PLC, L85 v34) where we'll have 20 motors installed, all controlled by powerflex 750 series drives. We need...
964
On my laptop I have an old.acd file with important comments in it. The file was modified and downloaded to my AB-1756 long time ago. Later a few...
1,995
I already succeeded in programming a function to find parameters of fifth order polynomial, in the runtime of a motion controller. To use if at...
1,965
