Modify string in Red Lion PTV
ggrice_71
Jun 2010
South Georgia
I set up a ProducTVity Station to read data queried from a SQL view. I moved that information into string tags to display on a large TV.
I have a string:
“Palletizer Control - Pallet Unwrapped”
I want to remove everything to the left of the “-“ so the new string becomes:
“Pallet Unwrapped”
I can't find a function that accomplishes this. I'm pretty sure this can be done with scripting, but I am not that familiar with the syntax Crimson uses. Does anyone have an example of what the script that does what I need looks like in crimson?
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
435
Hi. I'm working with a SLC 5/05 but I have no experience with it. I've been tasked with trying to figure out if it is possible to directly modify...
1,065
I am building a report screen with a SQL table display, and I want to be able to adjust the time range from which data are pulled (something I...
886
Hi, Wondering if anyone has had experience/knows how to modify the multicast address of EGD Data being produced. My PLC has Producer Id...
1,984
