Module Help Needed
Mark Buskell
Sep 2003
Florida
892
I have a school project where I need digital (120V) 7 outputs but all the modules I find are 8 outputs or more. Does anyone know who makes one?
it never hurts to have a spare. what brand of plc? I do not belive you will find a card with only 7
you will just have to get an 8 output card, and leave the last as a spare. there is nothing wrong with having an unused input or output. plus with addressing commonly being 0-7 (at least for AB) for an 8 output card, u could always leave the '0' free and use 1-7 :ROFLMAO:
I like using the Math Module cards for situations like this. They perform the calculations required to get you the outputs you need. You simply install them in to the next slot adjacent to the module you need to alter. For example, if you had a 16 point output module, but only needed 8 outputs, you would need a 'divide by 2 module'. In your case, you would need to purchase and install a 'minus one' module. The neat thing about these cards is that you can calibrate them with a calculator.
Hi. I have an OMRON PLC CJ1M (cpu 13) with an analog module MAD42. This is my first time working with OMRON PLCs and im having a hard time...
2,638
Hello everyone, I need help with programming 1746-BAS module. I am able to connect to PRN1 port via Hyperterminal and execute commands, even...
20
5,452
Hey, thanks for a great side. My question is: " is it possible to use the USB simatic pc adapter to, directly communicate with a dp enabled...
3,244
This might be a long shot, but we are in need of a Dupline Part # G21960002700. It's the master interface for a GE-90-30. Carlo Gavazzi is...
2,882
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
275
