Omron MAD42 module help needed
Eddelweiss
Jan 2016
Toronto
Hi. I have an OMRON PLC CJ1M (cpu 13) with an analog module MAD42. This is my first time working with OMRON PLCs and im having a hard time understanding the manual for it.
What im trying to do is send a current signal in the form of 4 to 20 mA from the output 1 of the analog mad42 card to a vfd. Basically im using the 4-20 to control the frequency of the vfd.I also need to send a 0 to 10 V signal from a sensor to the input 1 of the analog mad42 card.
So far i have enabled the all the analog channels, i have set my output to give 4-20 mA and my input to give 0-10 V. The problem now is how to i actually write the ladder program for that and also how to do the scaling so that the plc can send and receive the correct signals. Ive read the scaling chapter in the manual but im not sure if i should set my 4mA to 0000(hex) or to just 0 in decimal, or should i just leave it at 4. Any help will be greatly appreciated.
Thank you in advance
The range of values for either 0-10vdc or 4-20ma will be 0 to 4000 decimal or 0-8000 decimal depending on how your module is set. The first input value (assuming it is module 0) will appear in CIO address 2005. The data written into CIO address 2001 will be sent to the first output.
I can see CIO 2005 value changing in the memory table when I change the analog input, but how do I convert it to decimal to be read from an HMI? I dont believe I can read CIO direct?
Hi all, i was trying to learn the analog card and got pulled off. now i am asking for your help again. this is what i have. all i/o are enabled...
1,308
Hi all, While i am not new to omron, i'm totally new to the analog part and lost. i have a CJ2M cpu 33. then there are 4 i/o cards card 5 is a...
26
2,589
I have little to no experience with Omron. A co-worker is trying to set up a MAD42 Analog I/0 card with a CJ1M CPU 11 on a little trainer unit. He...
2,923
Hey guys, first time posting here. I am having trouble reading a 0-10V input into the MAD42 module on the Omron PLC. I have already switched the...
2,290
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
166
