Omron MAD42 Set Up
MitsM83
Jan 2017
Indianapolis
90
I have little to no experience with Omron. A co-worker is trying to set up a MAD42 Analog I/0 card with a CJ1M CPU 11 on a little trainer unit. He wants to bring in a Pot value and display it on a 7 segment display. I was asked to help. 🔨 It is in "slot" 2. The input is working. Using input 2 and output 2. I am getting the pot value into CIO2005 and using a MOV command to CIO2002 but I get no voltage to the Output. What am I doing wrong? Even if I force a value into that word I get no output.
So it points to a piece of software called Sysmac Studio to set up the variable table. Then the manual explains set up with this table. Is there a way to set it up without this software? I have tries using the settings if you right click on it where you set up your rack and go to Unti Setup with no luck. I feel like I am missing something that would be included in the variable table.
Or a list of the D20000 range, like what each bit is.. I could count from the variable table in the manual I suppose but might take a while.
Thanks,
Hi all, i was trying to learn the analog card and got pulled off. now i am asking for your help again. this is what i have. all i/o are enabled...
1,308
Hi all, While i am not new to omron, i'm totally new to the analog part and lost. i have a CJ2M cpu 33. then there are 4 i/o cards card 5 is a...
26
2,589
Hi. I have an OMRON PLC CJ1M (cpu 13) with an analog module MAD42. This is my first time working with OMRON PLCs and im having a hard time...
2,634
Hey guys, first time posting here. I am having trouble reading a 0-10V input into the MAD42 module on the Omron PLC. I have already switched the...
2,290
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
166
