redwood1957
I have several stations with AB Micro 1200's. At this time they get inputs for two pumps starts and then acumulate run time for each motor.This is then sent via radio modem to a master for alarming.I would like to do the following monitor that the motors are alternating starts, run time is within x amount of each other and alarm if there is two starts with out the other. and monitor run times to see if one pump (motor take excessive run time to satisfy the level set points.
Any suggestions on this.
