Monitor UDP device on Profinet
Wolverine458
Mar 2006
Michigan
19
I have a device that outputs a status packet over UDP protocol that I want to capture and monitor with my Profinet network. Does anyone have knowledge of doing this? I see a lot of gateways to Profinet but I have not seen one for UDP.
Most Profinet controllers also support TCP communications. Most of the devices that support TCP comms support UDP as well.
Which PLC are you using?
A lot of machines are CNC 840D, but also S7 300 and S7 1500.
In the S7-300, look into the TUSEND/TURCV blocks. For an example from the support site:
https://support.industry.siemens.com/cs/ww/en/view/29738463
In the S7-1500, the same blocks can be used, but I think the new instructions TSEND_C/TRCV_C simplify things a bit. They include the connect/disconnect blocks into a simpler interface. This example is for the 1200, but it works the same in the 1500.
https://support.industry.siemens.com/cs/ww/en/view/67196808
I'm not 100% sure of the 840D's capabilities, but I think it uses AG_send/AG_recv.
In all of these cases, you should be able to do the Profinet communication at the same time as the UDP communication.
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
107
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
198
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
374
We finally replaced our Cognex Checker with an IV-3 and I'm wondering if can replace the s/w in the monitor with anything else. I haven't been...
108
Im very new to programmin,but i was wanting to try and set up a program that could monitor the speed of a roller. Would it be possible to use the...
165
