Monitor vibration
Holmux
Oct 2013
Aalborg
279
Dear all
I am starting on my first task where I need to include monitoring vibration and have been calling around to different suppliers to get some guiding on where to start, the standard reply so far has been "please take a look in our catalog and tell us what you need" ???
Well that is my first problem, I have learned so much that I need to narrow down the (g) force and the Hz that I will be playing with, so is my first step to get a handheld tester and try to shoot on the range where i will be working ?
I have a feeling that i am very low in frequency, it is a large steel structure hanging down from the ceiling, whit some overhead conveyors, moving pigs and sows.
The position where I will have to measure will not be possible with a handheld unit, but I would probably get a good idea from measuring the surrounding structure, If I need to go and get myself a test unit, is there any one with some experience that could give me a hint?
On the sensors it self it looks to me like they are split into two different Technics Capacitive or Piezoresistive, not sure if there are more to pick from, but I am trying to learn the difference between the two pros/cons is there any guideline i need to follow?
Sorry this was a lot of questions with very short description, I hope someone will help pointing me in the right direction.
Thanks in advance
Holmux
I've only monitored rotating machinery, not structures. You probably don't want capacitive - the measure the change in gap between themselves and the moving component, like the gap between a journal bearing and a shaft.
Piezoelectric seems like the best bet. Metrix is one company with a broad line of machinery monitoring.
You will need some idea of the displacement and frequency under consideration.
I suggest you try to find someone in earthquake monitoring. They may be able to give you some ideas.
or you could go low tech on it and buy 2 laser sensors that will return a distance, and monitor that over time and do some math to calculate a frequency and how much things are moving.
This obviously may not be the best solution but a fun alternative.
Thanks for the reply 🍻
I am trying to find a vibration data-logger with a wide measuring range, that I can mount for a day to see what is actually going on, they don't come cheap but I have a feeling it is a good investment.
The laser option actually crossed my mind a few times, but I am not sure I can find anything in the hole room not moving :)
So I think I am stock with good old gravity.
Another thing I have already learned is that most of the sensors are build to order, so delivery time is very long, but I will keep surging and keep you updated.
Thanks again
Thanks again
www.dewetron.com
They have everything you need. Probably dewe-43 and some Imi gravity sensors are best solution.
Dear All, Is there any way to simulate vibration program on RSLogix 5000 using Emonitor? Regards, Mitsupuri A.P
2,510
Hy, we have a "Bently Nevada 7200 RV-R vibration monitor" which needs to be replaced by a new equivalent product. Can you help in selecting...
5,159
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
101
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
194
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
363
