LadderLogic
Do you have any suggestions for which Codesys package to use?
I would suggest Beckhoff TwinCAT 3, but this is my personal preference.
Since you are in TX, if you do anything with oil & gas chances are you will run across controllers using Codesys, and everyone else.
I have a buddy that used to use AB exclusively. He branched out and snagged a job with a company that needed a PLC programmer for one of the lesser known brands.
Would it be fair to say that his exposure to various process/machine control systems was greatly expanded because of the market share of AB? Allowing him to gain a broad experience, and confidence required to branch out to a lesser known PLC?
It's not just about learning software, it's about getting exposed to what control systems are out there, what process and machine control mechanisms are in use. Working with a brand that controls a large market provides a beginner the means to get involved, get exposed, and most importantly be mentored.
Hi,Hi all, I am looking to learn some PLC programming software in depth. I'm debating between learning Codesys and RsLogix, but am open to other programming software also.
To help me decide, I'm trying to figure out which is more used. I know AB has a huge presence in NA, but is it big enough to justify learning RsLogix over Codesys which is compatible with so many PLCs? Is there another brand perhaps that is even more used that I'm overlooking?
I have experience working with Allen Bradley, Beckhoff, Omron, Modicon PLCs plus more and my expertise is more on the SCADA side. I'm wanting to better round out my skills by being an expert in at least one PLC programming software.
My interests lie more in the robotics side than the manufacturing side too.
Thanks in advance!
If you want to make $ any of the above will do, but if you want to make $$$, DeltaV is the way to go.
From what I have briefly read, robotics is on a different software path than normal PLC's. Browse National Instruments website since I recall they were pushing a universal robotics programming tool (LabView-based?).
Perhaps the closest overlap between robotics and automation is in motion control. Look at Galil and Delta Computer. The later is/was working on incorporating normal PLC coding into their motion controllers. CNC programming also overlaps. Look at Beckhoff Automation's TwinCAT, which can integrate CNC G-code with a PLC project, and also has kinematics calculation tools (convert desired x,y,z positions into manipulator's angles, ...). Electric motor drives is another specialized area that overlaps.
These threads always kill me; "I want to learn the ONE software to rule them all!"
Just because a company owns the largest market share, doesn't make it the best software to know.
If someone owns a lot of market share, then that area is probably over-saturated with people that know more than a beginner. Which makes the job search difficult. Knowing a variety of software packages will make you much more useful to the job market. More so if a few of those software packages are from companies that have smaller market share as the number of people that will be fighting for that same job is an incredibly smaller pool.
I have a buddy that used to use AB exclusively. He branched out and snagged a job with a company that needed a PLC programmer for one of the lesser known brands. Now all he does is contract out to folks that need someone who knows the lesser known brand. He makes a pretty good living by being specialized in a field that doesn't have a lot of competition.
As was said before; there is no "Right" answer. The right answer is what is going to get you your first job. Once you get that first job, think about learning something else. It might land you your second job. The more you know, the more you earn.
Thanks in advance!
