Synchronized motion falls under the three following main categories:
1. Electronic gearing : Master/Slave velocity following
2. Electronic camming : Master/Slave position following
3. Interpolation: CNC
So, you have to figure out which architecture from the above does your application fall under, if it's synchronized motion. Then you can select the required hardware.
Thanks.
