Motor Locked Sinamics S120
Your trace was there, but is now not visible.
My comment - you need to show speed demand as well as speed feedback - it would appear you have a synchronous motor so you can replace the current feedback with speed demand.
Okay. I will add those values. Which one from the list. Looks like many speed tags.
Something certainly seems to be holding the axis from moving based on how the position jumps when the torque disappears. And whatever it is must be pretty stiff given how quickly it moves and settles. Gear teeth are just as likely as anything else at this point.
Keith
I had trouble for a week trying to get a Marathon Symax Motor autotuned to work with a Powerflex 753 drive. I solved the problem and thought I...
47
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
303
251
352
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
177
