I want to maintain a constant pressure of 5.3bar in a compressed air ring main by exhausting air through a silencer using a 1inch ported Valpes motorised proportional valve. The air demand varies from high to low throughout the day so valve position will continually change. There's a 0-10bar 4-20mA pressure transmitter in the air line which is used to measure and record pressure.
So far so good. Now the bad bit. The only tool left in my toy box is an SMC/Mitsi Alpha 10 i/o controller.
How can I use the output from the pressure transmitter to control the input to the motorised valve?
Thanks for your help!
