MSG instruction help
A_G
Jul 2014
MA
370
I'm trying to use a MSG instruction to get data from a SLC into a ControlLogix. I want to read some Boolean tags from the SLC. Is it possible to do this? When I set up the MSG instruction in the ControlLogix, I get this error: "Message references a tag of BOOL data type". Is it possible to read Boolean tags using MSG? Thanks in advance for any help!
Try reading INT and later you can use the bit you need. First you need to include your bool into a INT.
Thanks, this is what I ended up doing. So I included the whole B3:0 in the MSG.
Thanks for posting the follow-up.
16-bit words in a "B" file in a classic A-B controller (PLC-5,SLC-500 or MicroLogix) are treated just like words in an "N" file and are readable in 16-bit elements.
The reason that BOOL elements and individual bits of any B or N file cannot be addressed by a MSG instruction is a practical one based on technical support experience.
The theory is that if you allow programmers to read individual bits with a MSG instruction, they will be tempted to actually do so, and will use up all the memory and buffers in the controller moving around a handful of bits one at a time.
So Rockwell simply doesn't allow it, forcing programmers to at least move sixteen bits at a time.
Hello All, This might be a simple question for most of you. I am working on performing some tests on an EIP device through RSLogix 5000. Based...
2,042
Hi, I'm trying to ensure I have the correct path to allow msg read from 5380 processor via compactlogix. The SI has installed it in a way I'm not...
6,515
Hello all. I need some help setting up a MSG instruction to transmit 10 bits of data from a compact Logix processor to a micrologix 1400. I have...
31
20,058
Good morning everyone. I'm relatively new to the Allen-Bradley world. My issue I'm facing is this. I have a remote Refractive Index sensor...
2,253
The good news is I became a dad today, i'm posting from the hospital at this moment. the bad news is i've still not figured out reading my...
19
5,116
