Multi-dimensional FGEN equivalent?
Paul351W
Mar 2008
Northern Illinois
154
I am working on a motor control project that may require me to send a current command based on speed, as well as torque requested, if the current to torque relationship does not prove to be linear.
I am familiar with the FGEN function, having used it several times, but it can only deal with one variable (Y) instead of two. I may need to have a table of torque to current values for various speeds and interpolate between them to issue the correct command but I am not sure exactly how to go about that, short of doing it all manually, or running multiple FGEN functions and doing the interpolation manually.
I have read a little bit about the MCCP instruction, but I have never used motion instructions before so it is not very clear to me if it can do what I need or not.
Anyone have any ideas/suggestions?
RSLogix or?
FGEN can be done in Function Block or Structured Text in the Controllogix and Compactlogix PLCs. And it supports X and Y with you telling it how many DINTS are in the X and Y.
Sorry bout that. This will be on an L62 controllogix processor. After some thinking I might be able to do a two stage computation with 3 FGEN instructions and some arrays.
Hello all, I am working on a project with an s7-1200 and I am controlling three stepper motors using this controller. I will be receiving input...
2,405
Hey guys, I am having issues, which I believe to be with data that is not visable.. I am wondering if anyone has a source describing the lengths...
2,813
I can't for the life of me figure out how or even if making 3D arrays is possible. I can get a 2D array just fine and stings are obvious. I'm...
6,275
Hi, I'm having problems getting crimson to map tags with data in a 2 dimensional array of a user defined data type. Its a control logix plc and...
4,961
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
287
