Multi-position linear motion
Mots
Apr 2014
Perth
Hi guys, I don't have a lot of experience with multi-position linear actuators and I am unsure of what would be the best/most economical solution for my application.
I need 2 of these actuators that will need to push an item anywhere between 0 and 4.5m length. The maximum required force would be about 400N. It doesn't need to be very precise, +/- a few mm precision will be more than enough.
I was thinking about a driven linear slide, but never used them before. Would there be anything else better for this application ? They will have to be controlled by a PLC.
Thanks for your input guys, I am pretty much a newbie regarding automation/actuators so your help is greatly appreciated.
Cheers
Doesn't have to be very fast, it will to be used once every 2 minutes. If it could do 1m/s that would be more than enough.
Thanks for your help.
4.5 meters - wow! Maybe you'll need to use a rotary servo or stepper device and chain drive a dog mounted to the chain to gain that kind of length?
Osmanmom, yes belt driven linear guide would be perfect for my project. When I click on your Parker link it brings me to the HPLA model, any reason for this model in particular ? From experience, would you know what kind of cost are involve for such an actuator ? Any benefit of going with the electrical rodless actuators instead of the belt driven ones ?
danatomega, yep, depending on the cost of these rodless actuators, this would probably be the most cost-efficient solution. What do you call a "dog" to be mounted on the chain ?
Cheers guys !
This stuff Belt Driven Linear Actuators ~ Standard from Parker are expensive i guest (always expensive) i give this example for your reference only due the length required.
if you can effort contact local rep.
for low/medium cost use the suggestion from danatomega
chain or belt,pulley/gear teeth,linear slider/straight rod steel.
Custom make.
i don't know your site environment.
check your mechanical/spec requirement work with mech engineer.
servo drive will be another long subject.
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
300
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
152
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
595
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
525
Good Morning , We have a Ishida Multi-Head Scale . I had experiece with them for chips , crackers , etc. , but now we are using them for...
488
