HalfManHalfBiscuit
I want to add some logic to an existing 1756-L73 processor to add enhanced monitoring functionality. My problem is the existing program in the processor is already running with a scan time of roughly 120 msec and cannot have any additional scan time added to it. I was wondering if it would be possible to add an additional 1756-L73 processor to the chassis and download the same program to it and have it run in a sort of "listen" mode where it read the same real world inputs and executed the same code minus writing to real world outputs. I would then add my driver to this 2nd processor. I would always want the 1st processor to "own" the outputs. Some of the connections are non-Rockwell components and don't support the "listen only" mode so I have a bad feeling about this. I know ideally it makes sense to take this process and split it up completely between 2 processors to reduce the scan time. Unfortunately this processor is already running in a production environment and is already behind in producing parts for one of the big 3 auto suppliers. Current risk is too high to go that route.
