my plant recently purchased 2 used equipment
Feb 2007
Richmond Hill, Ontario
40
with siemens plc s7-300, cpu 315-2dp, SM321 DI card, 32x DC 24V,
SM322 DO card, 32x DC 24v
HMI: 6av2-124-oGC01-0AX0
C-B8A26628
00-0E-8C-FC-AC-DC
I had trouble connected plc online, if anyone can give me a hand, I will really appreciate, I believe one of our module port not working well, need to programme it because no module in stock, if anyone can help me out, I will really appreciate it.:geek::geek::geek::geek::geek::geek:
Are you certain that you have software that will work with this Siemens PLC? Not all newer programs will run on the older units (without PLC firmware updates).
How about you tell us what hardware you have for going online ?
And what settings you have for that hardware ?
I am surprised that you say that the equipment is used.
The 6AV2124-0GC01-0AX0 is a TP700 comfort panel which is very new.
Hello guys, I would need some help. I have installed the aveva plant scada and want to run a project. From the configurator, all are fine, as I...
119
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
700
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
184
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
302
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
369
